Scangauge II Horse Power Readings FYI
There have been a couple of questions about how the Scangauge II measures horse power. I emailed the company with the following question and got the reply below.
----- Original Message -----
To: <scangauge@linear-logic.com>
Sent: Wednesday, January 09, 2008 8:40 PM
Subject: Horse Power
> Sirs,
> Could you explain what parameters my ScanGauge II uses
> to calculate horse power in my 2005 V6 Tundra. How
> does that reading compare to a dyno. What is the plus
> or minus accuracy of the HPR reading?
> Thanks,
> Zac
Add to Address Book Add Mobile Alert
To: "XXXXXXX XXXX" <XXXXXXXXX@yahoo.com>
Subject: Re: Horse Power
Date: Thu, 10 Jan 2008 14:04:09 -0700
Hi,
The HP reading that the ScanGauge does is an internal calculation. It
should be pretty close to the grose horsepower that your engine produces. We have done testing on several cars at a dyno and found the ScanGauge to be reading around 15-20% higher then wheel hp.
Please let me know if you have any other questions.
Thanks,
Joey
