Re: Oil filled from the Factory?
Henry T is correct. Toyota does not specifically recommend synthetic for the Tundra, all though you can certainly use it if you want. Toyota only recommends that if you use synthetic, you do not switch back to dino oil.
In the end, synthetic or dino makes no difference so long as you stick with one or the other and use the proper grade/weight.
2007 SR5 CrewMax, SiLver w/5.7 V8
>Bakflip Tonneau Cover.
>Rampage Running Boards.
>Heavy Duty 6 ft. Rubber Bed Mat
out of my 2000 Tundra cut to fit!
