Old 01-12-2008, 04:06 PM
TENTundra TENTundra is offline
Last Online: 07-21-2008 03:43 PM
TENTundra is on a distinguished road.
TENTundra's Photo Albums
Default Re: AMP Research Powerstep running boards
Originally Posted by Gunner Tundra View Post
Thanks for the info. I'll be placing my order shortly. The install looks fairly simple, just wondering if it has some sort of safety feature in case something gets caught in between the board and body as it is coming up?
Actually there is a safeguard to prevent your foot from getting caught up in it. The step is pressure sensitive. I believe in the brain it measures the motor current draw which would increase in the event that something is obstructing the board. As you will see after you install them, by simply keeping your foot on the step and close the door, the board will sense the weight of your foot and not close. The technican at AMP told us that even if you were to manage to get your hand caught in it, the sensor is so sensitive that it will sense the resistence and immediately withdraw the step back down.
