Old 01-12-2008, 08:15 PM
Gunner Tundra's Avatar
Gunner Tundra Gunner Tundra is offline
Last Online: 11-21-2009 12:08 AM
Gunner Tundra is on a distinguished road.
Gunner Tundra's Photo Albums
Default Re: AMP Research Powerstep running boards
Originally Posted by TENTundra View Post
Actually there is a safeguard to prevent your foot from getting caught up in it. The step is pressure sensitive. I believe in the brain it measures the motor current draw which would increase in the event that something is obstructing the board. As you will see after you install them, by simply keeping your foot on the step and close the door, the board will sense the weight of your foot and not close. The technican at AMP told us that even if you were to manage to get your hand caught in it, the sensor is so sensitive that it will sense the resistence and immediately withdraw the step back down.
Now that's innovative! Thanks for the info. I'm sure my wife will appreciate the safety feature as we have a two year old running around.
2007 Tundra CrewMax LTD 8272 Black/Sand Biege - Navigation, Rear Seat Entertainment, 20" Alloys, Sunroof, Mudguards, Sonar, DTR, V2 Alarm w/GBS.
MODS: Line-X, RETRAX, Tech Formula Paint Sealant, Debadged, Clear DRL's, AMP Powerstep Running Boards, 2.4" ReadyLift, Nitto Terra Grapplers 305/55/20's on OEM LTD 20" Alloys, Ravelco Anti-Theft Device, aFe CAI Stage 2 ProDry S, Corsa Performance Touring Exhaust. NEXT MODS: TRD Sway Bar, Auto Tailgate.
2000 4Runner LTD Millenium Silver 2WD - TRD Intake Air Filter, Clear-Corner Parking lenses, partial Debadge. Removed: Poweraid Throttle Body Spacer
1965 Ford Mustang 289 cid Laser Red - 5 spd, McLeod Clutch, Hydraulic Slave Clutch Cylinder, 3:89 Trac-Loc, 9" Lincoln Versialles Differential, 4 Wheel Disc Brakes, SVO Aluminum Master Cylinder, Simmons F90 custom wheels with Front/Rear width off-set, TFS Twisted Wedge heads, Holley 650 Double Pumper, Crower Custom CAM, Hooker Headers, Flowmaster w/H-pipe 2.5", SPAL fan, Weiand Stealth Intake - Mid 13's at 104 MPH street tires!
SOLD: 1993 Toyota Truck Xtra Cab SR5 2WD - E&C Spring UCA 3" lift, ProComp 3" Body lift, ProComp ES3000 Shocks, Rear Add-A-Leafs, 14mm Sway-Away Torsion Bars, Custom Skidplate and Driving light bar w/PIAA 40 Driving lights, Hella H4 Headlights, Optima Battery, Jacobs Omni-Pak w/8.5mm wires, K&N FIPK, FlowMaster 2 Chamber 2.5" CAT-Back Exhaust, 10 deg. Advanced Timing, Western 15x8 wheels, BFG TA KO's 31x10.5x15, 4.11:1 Gears w/Tru-Trac TracLok.
IYAOYAS!
