Originally Posted by Jleonard
Not sure if I missed it, but do they have an audio input where I could plug headsets directly into the unit? I was thinking about getting a little speaker one would use with an mp3 player so she doesn't have to wear headphones?
Well there are a couple of ways to do this with this setup and sure with others similar. It does actually have a spot in the middle of the screen area were you can plug a audio headset directly into them. They actually supply 2 sets with this setup I got. You can use the FM modulator part and just tune your stock radio to a freq not used in your area, this is adjustable on each headset and listen through the stock head unit or last option is feed the audio out of the headreast you like into say the AUX input of the radio for a cleaner sound and play through your stock head unit.
Hope that helps answer your questions.
I plan to eventualy feed the audio and video outputs to my stock NAV head unit but just haven't doen it yet, similar set up as what Wilee on here has doen with his unit. He actually got some good information on his site and in a post around here about it too.
