Re: Eclipse Navi Unit 5435.
Yes. There is a wire that needs to be hooked to the parking brake. The NAV functions are not available until you depress the parking brake.
You can simply ground this wire to the vehicle chassis to fix the problem.
There are two other wires that need to be connected.
1) Reverse sensor wire
2) Speed/Pulse wire
Of course, you will need to attach the GPS antenna and mount it as well.
05 Sequoia 4x4 Ltd. Phantom Grey Pearl, Weld 20" wheels on Toyo tires, MagnaFlow cat-back, Amsoil fluids, custom 15" overhead DVD system, Eclipse NAV system w/camera, Sirius tuner. DLS Nobelium components and coaxials, TRU B-2110 and H-1 amps, 13" eD sub, iPod hookup. SilverStar lamps.
