Old 01-19-2008, 04:31 PM
Mdecsh Mdecsh is offline
Last Online: 10-29-2009 07:07 AM
Mdecsh is on a distinguished road.
Mdecsh's Photo Albums
Default Re: tundra serpentine belt
Hello to all you serpentine belt experts. After reading all the messages, I finally went to work replacing the squeeky belt on my 2003 Tundra. The replacement took about 20 minutes and was relatively easy. I have a few clarifications to pass along so that those of you are somewhat mechanicaly challanged like me will be able to replace your belt too.
First; to loosen the belts you have to know where the belt tensioner is. It's the one on the diagram that notes that it has a left hand thread. Using a breaker bar and 14mm socket, turn the bolt counter clockwise until it hits a stop. Don't muscle it as it will only turn about 20 degrees or so. Then start the belt removal. This will take a total time of 30 seconds. Next; remove the breaker bar and start threading the new belt and make sure it's a Goodyear Gatorback. They are available at AutoZone for about $25. For the next 19 1/2 minutes, you will be struggling to get the belt routed correctly. Follow the diagram on the decal located on the right front side of the engine compartment. If the diagram is missing or illegible, make your own diagram by following the routing before removing the old belt. Route the belt so that the last 2 pullys to be hooked up are the one on the lower drivers side and the smooth pully that connects to the fan. From beneath the car, reattach the breaker bar and turn it counterclockwise as far as it will go. If you are by yourself, hook a strap the the end of the breaker bar and lash it to the frame. This way the tensioner is fully retracted, allowing you to route the belt first over the lower pully on the drivers side. Do this from under the engine. Next; from the top of the engine, start sliding the pully over the pully connected to the fan. This will be hard, but by turning the pully by hand, the belt will slide on nicely. Next: check to make sure the belt is correctly positioned on all the pullys and if all looks well, release the breaker bar and the belt will tighten up. You are done. Take a drive down the street and notice that people no longer look at you as if you are a disgrace to the automotive industry.
Thanks to all of you that helped me get this done.
Marc
