Thread: 4-inch lift
Old 01-20-2008, 02:35 AM
DanielAcosta's Avatar
DanielAcosta DanielAcosta is offline
Last Online: 11-20-2009 10:15 AM
DanielAcosta is on a distinguished road.
DanielAcosta's Photo Albums
Default Re: 4-inch lift
Problem with the Camburg is I am not sure it would fit with the stock wheels. I am not interested in decreasing offset and having tires that stick out beyond the fender. I do appreciate the advice, though, about keeping track of the ball joint wear.
I can tell you there is more travel left than with a similar arrangement I had on my 05 Frontier. With that truck, the suspension would top out on large bumps; no negative effects noticed so far with the Tundra.
07 DC SR5 TRD 4x4 5.7 TRD exhaust, 46K miles, 17 mpg city after battery disconnect reset. Truxedo Lo-Pro with deck rails. Front Susp: Stock coilovers, 4" lift (http://www.tundrasolutions.com/forum...6-4-inch-lift/), swapped extra spacers for Bilstein 5100s on lowest setting, wheel well height still 41.5." Rear Susp: ProComp ES3000 #326510 (2.25" taller than stock), 1.25" blocks plus PRG mini-pack (http://www.tundrasolutions.com/forum...and-new-truck/) gives 2.25" total lift, parking brake cable bracket spacers, wheel well height 43." Front diff and rear ds drop; trailer hitch electrical harness tucked up above bumper. After 20K miles swapped 305/65/18 BFG AT for 285/75/18 Toyo AT, still on stock 18x8x60 offset TRD wheels, about 1/8" clearance to sway bar. Like the extra height but miss the width. Next time either 305/70/, 295/70, or 35x12.50/18. Added 5th 285/75/18 Toyo AT as spare. Bed Bounce: Stiffer E-tires are worse than stock P-metric; biggest improvement from PRG mini-pack, slight improvement from shocks. Still a stiff ride but tolerable now. Best things about this truck: 5.7 and transmission, interior size and comfort, very quiet at high speed. Worst things about this truck: bed bounce, no VSC in 4wd, mileage sucks above 70.
