Thread: 4-inch lift
Old 01-20-2008, 09:07 AM
DanielAcosta's Avatar
DanielAcosta DanielAcosta is offline
Last Online: 11-20-2009 10:15 AM
DanielAcosta is on a distinguished road.
DanielAcosta's Photo Albums
Default Re: 4-inch lift
Originally Posted by Fromanhb View Post
I would give them a call about the stock wheels. I'm pretty sure they will allow for stock wheels with their light setup since it's only coilovers and upper arms. Now the long travel kit is something I will only be dreaming about, if you've ever ridden in a long travel truck it's addicting!
I believe the Camburg kit you are describing only gives 3 inches of lift, not to mention the question of whether it would clear stock wheels with oversize tires. My current set up only has about 1/2 inch clearance to the UCA, and of course needed the usual skid plate tweak.
07 DC SR5 TRD 4x4 5.7 TRD exhaust, 46K miles, 17 mpg city after battery disconnect reset. Truxedo Lo-Pro with deck rails. Front Susp: Stock coilovers, 4" lift (http://www.tundrasolutions.com/forum...6-4-inch-lift/), swapped extra spacers for Bilstein 5100s on lowest setting, wheel well height still 41.5." Rear Susp: ProComp ES3000 #326510 (2.25" taller than stock), 1.25" blocks plus PRG mini-pack (http://www.tundrasolutions.com/forum...and-new-truck/) gives 2.25" total lift, parking brake cable bracket spacers, wheel well height 43." Front diff and rear ds drop; trailer hitch electrical harness tucked up above bumper. After 20K miles swapped 305/65/18 BFG AT for 285/75/18 Toyo AT, still on stock 18x8x60 offset TRD wheels, about 1/8" clearance to sway bar. Like the extra height but miss the width. Next time either 305/70/, 295/70, or 35x12.50/18. Added 5th 285/75/18 Toyo AT as spare. Bed Bounce: Stiffer E-tires are worse than stock P-metric; biggest improvement from PRG mini-pack, slight improvement from shocks. Still a stiff ride but tolerable now. Best things about this truck: 5.7 and transmission, interior size and comfort, very quiet at high speed. Worst things about this truck: bed bounce, no VSC in 4wd, mileage sucks above 70.
