Re: My wife wants an FJ Cruiser...or an Xterra
FJ Cruiser Trail Teams Special Edition is best if you want a look of off road and and great quality here are some specs for the Model stated above
Specifications
Exclusive Iceberg paint
Matte black bumpers, mirrors and door handles
Bilstein® shock absorbers
Cyclone air cleaner
Differential lock and A-TRAC
Floating ball-type multi-information display
Bumper-Mounted Auxiliary Lights
Front Skid Plate
Rear Skid Plate
Rock Rails
All Weather Mats/Cargo Mat (5 piece set)
Trail Teams Special Edition badging
TRD Performance Exhaust System
16-in. TRD alloy wheels with matte black powder-coated finish
Special Edition shift knob and transfer case lever
P265/75R16 BF Goodrich® All Terrain Tires
Remote keyless entry
Cruise control
Power outside mirrors with markers
Rear privacy glass
Rear wiper
Rear parking sonar
Daytime Running Lights (DRL)
Leather-wrapped steering wheel with integrated audio controls
Exterior color-keyed door trim inserts and instrument panel
AM/FM 6-disc CD changer with MP3/WMA playback capability and nine speakers
115V, 400W power outlet
here is gas and features of the FJ cruiser above is special edtion which I recommend.
Mileage Estimates (mpg city/highway) [6] 2WD: 16/20
4WD manual: 15/18
4WD automatic: 16/20
Engine 4.0-liter DOHC 24-valve SFI VVT-i V6
239 hp @ 5200 rpm;
278 lb.-ft. @ 3700 rpm
Ignition Electronic, with Toyota Direct Ignition System(TDIS)
Transmission 5-speed electronically controlled automatic overdrive (ECT); 6-speed manual (full-time 4WD model)
Drivetrain Rear-wheel 2WD or part-time 4WD for automatic transmission models; full-time 4WD for manual transmission models; automatic limited-slip differential (2WD model)
Suspension
Front
Rear
High-mounted, double-wishbone front suspension and stabilizer bar (click here to see how IFS works);
4-link rear suspension with lateral rod with coil springs and stabilizer bar (click here to see the rear suspension in action)
Steering Power-assisted variable-gear rack-and-pinion
Turning circle diameter --
curb to curb (ft.) 41.8
Brakes Power-assisted 4-piston front/2-piston rear ventilated disc brakes with Anti-lock Brake System (ABS) with Electronic Brake-force Distribution (EBD) and Brake Assist [1]
Vehicle Stability Control (VSC) [2] Standard
Traction Control Standard
Active Traction Control Available (4WD model) (click here to see A-TRAC in action
2006 Tundra Double cab SR5 4x2 4.7L V8
