Thread: Truxx 3" kit
  #23 (permalink)
Old 01-23-2008, 12:11 AM
07kytundra's Avatar
07kytundra 07kytundra is offline
Last Online: 11-14-2009 06:26 PM
07kytundra is on a distinguished road.
07kytundra's Photo Albums
Default Re: Truxx 3" kit
Originally Posted by elsancho View Post
the cv/ball joint issue is minor between the 2 kits but the truxx kit will articulate the ball joint a little further than the toytech. This will occur because the Truxx kit allows for more downward travel because it has not extended the strut from the preloading of the spring. So at standstill both kits will have the same angles. But lift the front ends and the toytech kit will droop little if any (because its strut is almost at full extension) as opposed to the truxx kit which will droop as if it were stock. also remember that the ball joints articulate as well in addition to the cv's. im not sure what the specs are for the tundra BJ's and whether or not they are suspect to any binding or premature wear issues.
Which Lift are you using?
2007 TRD DC 5.7 Silver Sky 4x4
Truxx 3 inch front, Rear stock,
Pro-Comp 6066 20 x 8.5, Nitto A/T T.G. 305/55/20
Corsa Single Sport, aFe Intake
Fender Flares, Color matched door handles
Billet Grille (w/o cutout), 5% Tint
