Crewmax Stereo install - partially done!
This weekend I built a box for 2 - 12 inch Orion HP woofers. The box is 4.0 ft3 total tuned at 33 hz. I will install the woofers tomorrow evening as I ran out of time. It also rained off and on and I was outside since my truck wont fit into my friends garage!
I conected a line out converter on the output side of the JBL amp. It was a pain figuring out which wires ran what even with the wiring schematic I had printed at Toyota! I ended up going old school and I used a battery to find out which wires ran which set of component speakers! Simply hook up the battery to the wires and which ever speakers pops then you know which wires belong to it! Then I was able to connect the 4 outputs of the line out converter.
I am running a Directed D2400 mono amp (1200 Watts rms @ 1 ohm) for the subs and a 800 watt Orion 4 channel amp to the separates. Directed owns Orion, DEI, PPI, Viper, Python and quite a few other lins.
Here are a few photos of the partially finished install. Any questions, let me know!
Pro Comp Stage 6 inch lift
35 x 12.50 x 20 Toyo M/T's
20 x 9 inch Moto Metal 956 series
Clarion MAX685BT DVD player
Boyo back-up camera
2 - 12 inch Orion HP subwoofers
Orion 4 channel 800W amp
Directed Class D Mono 2400W amp
Kicker SS6.5 components
