  #18 (permalink)
Old 01-23-2008, 02:48 PM
ctbale ctbale is offline
Last Online: 03-08-2008 08:17 PM
ctbale is on a distinguished road.
ctbale's Photo Albums
Default Re: Timing belt replacement - What else should I get done at the same time?
Originally Posted by kathyricks View Post
The Tundra motor is an interference motor. There was one Tundra V8 owner on this forum who changed the belt at 90K, but didn't change the tensioner. Then at 174K miles, just before he was getting to change the timing belt again (at 180K) the tensioner seized during a full throttle passing manuver causing the belt to come off. Instantly his engine was destroyed when the pistons collided with the engine valves at full throttle. Lesson learned: Replace the tensioner at every timing belt change or live dangerously. Or change the timing belt sooner than 90K the second time it is changed and change the tensioner at that time.
ok, ok, replace the tensioner. My point is if you do a carefull inspection IAW the book, you will make 180k, then replace it.
