Old 01-25-2008, 07:20 AM
MEvang's Avatar
MEvang MEvang is offline
Last Online: 08-26-2009 09:37 PM
MEvang will become famous soon enough. MEvang will become famous soon enough.
MEvang's Photo Albums
Default Re: The good, the bad and the confusion with my recently attempted brake job
Yes, the load sensing valve should also be check if rapid front pad wear is a problem.
I know some people here have had good luck with Hawk pads but many have not. I think their pad break in proceeder is too aggressive and maybe they have changed this. But they are a racing pad manufacture and their formulas will be geared in this direction. Racing formulas are not always go for street use unless you tend to be a very aggressive braker, tow a lot or carry heavy loads most of the time.
I would not recommended these pads to anyone under normal circumstances, most people are much better off staying with the factory pads or a good name brand. This is my opinion based on 30 years experance in the brake and performanace car bussness.
Mike
“The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein)
Moderator Brake Forum
