Re: Toyota Brake Specifications Tundra 00-06
Tundra: 2000- 2006
Front Brakes
Calipers: Four Piston Fixed
Caliper to Upright Torque: 90 lbft
Maximum Parallel
Variation: Not Specified by Manufacture
Runout Limit: .0028"
Normal Thickness: 1.102"
Minimum Machining: Not Specified by Manufacture
Discard at or Under: 1.024"
Finish Microinch: Not Specified by Manufacture
Rear Brakes
Type : Drum
Runout Limit: Not Specified by Manufacture
Nominal Diameter: 11.614"
Maximum Machining: 11.693"
Wheel Nut Torque: 83 lbft
Brake Bleeding Sequence: None Specified
“The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein)
Moderator Brake Forum
