Re: Toyota Brake Specifications: Tacoma Prerunner '07
Tacoma: 2WD 4WD and Prerunner 2007
Front Brakes
Calipers: Not Given
Caliper to Upright Torque: Caliper Bolts 2WD except Prerunner, 27lbft 2WD Prerunner, 4WD Caliper Bolts 90 lbft; 2WD ex. Prerunner caliper bolts 80 lbft
Maximum Parallel
Variation: Not Specified by Manufacture
Runout Limit: .0020"
Normal Thickness: 2WD .984
4WD & Prerunner 1.102
Minimum Machining: Not Specified by Manufacture
Discard at or Under: 2WD .906
4WD & Prerunner 1.024
Finish Microinch: Not Specified by Manufacture
Rear Brakes
Type: Drum
Runout Limit: Not Specified by Manufacture
Nominal Diameter: 10.00"
Maximum Machining: Not Specified by Manufacture
Discard at or Over: 10.079
Wheel Nut Torque: 83 lbft
Special Bleeding Procedures:
1. Bleed the wheel brakes, no sequence given.
2. After bleeding air from the brakes system, if the height or feel of the brake pedal cannot be obtained, bleed air from actuator assembly using Hand-held tester by following steps below.
A. Depress the brake pedal more then 20 times with engine off.
B. Connect Hand-held tester to the DLC3
C. Turn ignition switch to the ON position
D. Select "Air Bleeding"
E. Bleed the air by following the steps displayed on the Hand- held tester
The significant problems we have cannot be solved at the same level of thinking with which we created them (Albert Einstein)
Moderator Brake Forum
