Old 02-01-2008, 06:22 AM
MEvang's Avatar
MEvang MEvang is offline
MEvang's Photo Albums
Last Online: Today 10:24 AM
MEvang will become famous soon enough.
Default Re: Toyota Brake Specifications: Tacoma, Prerunner '06
Tacoma: 2WD 4WD and Prerunner 2006
Front Brakes
Calipers: 2WD except Prerunner: Single Piston Sliding Pins
4WD and Prerunner 4 Piston Fixed
Caliper to Upright Torque: Caliper Bolts 2WD except Prerunner, 27lbft – 2WD Prerunner, 4WD Caliper Bolts 90 lbft; 2WD ex. Prerunner caliper bolts 80 lbft
Maximum Parallel
Variation: Not Specified by Manufacture
Runout Limit: .0020"
Normal Thickness: 2WD .987”
4WD & Prerunner 1.102”
Minimum Machining: Not Specified by Manufacture
Discard at or Under: 2WD .906”
4WD & Prerunner 1.024”
Finish Microinch: Not Specified by Manufacture
Rear Brakes
Type: Drum
Runout Limit: Not Specified by Manufacture
Nominal Diameter: 10.00"
Maximum Machining: 10.079”
Wheel Nut Torque: 85 lbft
Special Bleeding Procedures:
1. Bleed the wheel brakes, no sequence given.
2. After bleeding air from the brakes system, if the height or feel of the brake pedal cannot be obtained, bleed air from actuator assembly using Hand-held tester by following steps below.
A. Depress the brake pedal more then 20 times with engine off.
B. Connect Hand-held tester to the DLC3
C. Turn ignition switch to the ON position
D. Select "Air Bleeding"
E. Bleed the air by following the steps displayed on the Hand- held tester
“The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein)
Moderator Brake Forum
