02-02-2008, 08:48 AM
Re: Rear door full of rain water?!!
Originally Posted by jmell44
I know this thread is old but I have the same issue with the rear driver's side door; full of water. Clearing the drain holes is the obvious answer but where the drain holes are located is not. Of course I expect them to be at the bottom of the door, duh, but I sure couldn't find them. Where are they?
Also, why the same door? Coinsidence? Or is there an issue with the rear driver's side door?
Each one of the doors will have drain holes located to the outside of the last exterior door frame seal so the water trapped drains to the exterior of the car body. They may be round, rectangular or louver shaped but they'll always be at the lowest inside area of the doors seen when opened. Hope this helps you find them.
Larry
2004 Tundra V8 Limited Access Cab 4X4 , Auto Dim Comp/Temp Mirror, Aero Turbine #2525 muffler, Access Roll Up Cover, Optima D31A battery, Multi-Vex adaptive outside mirrors, Eclipse AVN5510 Nav unit and Sirius SIR-ECL1 tuner as of 10/07 pictures in my photo gallery
2003 Camry SE V6 Navigation, Sirius, Lunar Mist
Optima 34R battery
If a combo of all these whizz bangs met their claims you'd have to syphon gas out of your tank every second day and sell the excess horsepower on the third????
