Re: How-To: Search This Forum
Originally Posted by AaronV23
Sounds good, but you get everythread that mentions cold air intakes even though the thread may not be about the subject.
Indeed you do.
Here's how to search the TITLE's ONLY:
Follow same instructions as above, but click on Advanced Search.
On the next screen use the first drop down box and select Search In Titles Only.
This method should bring up only the threads with the chosen words in the title, not all throughout every post.
My Truck: 2005 Tundra, 2UZFE. 4WD. AccessCab. Spectra Blue Mica (8M6). TRD. AT. CC. CK. DZ. FE. AW. LD. OF. TO. VP.  Suspension & Tires: 285/75-16 BFG T/A'ko, Fabtech Coils, 1.5" Wheeler's blocks, Toytec Diff Drop, 1.25" Spidertrax [front], 1.5" Goeske Wheel Adapters [rear] Handling: TC Poly Steering Rack Bushings, Downey HD End Links, Wheeler's Anti-Sway Kit, Hellwig 7700 Swaybar, Timbren Rear SES Electrical: URD MAF Sensor Calibrator, Superlift Truspeed Speed Sensor Re-Calibrator, ScangaugeII, Full LED Conversion Stereo: Alpine CDA-9886, Alpine & Phoenix Gold amps, Q-Logic box w/RF subs, eDead Cosmetic: Line-X Bedliner, Custom N-Fab Steps, Rear Diff Breather Extension, F103N Fumoto Oil Drain Valve, Debadged (partially), Bell Truck Trunk, Access Vanish Tonneau
