Old 02-04-2008, 12:20 PM
DanielAcosta's Avatar
DanielAcosta DanielAcosta is offline
Last Online: 11-20-2009 10:15 AM
DanielAcosta is on a distinguished road.
DanielAcosta's Photo Albums
Default Re: what offset do I need?
Originally Posted by Wildbill Tundra View Post
Bout to get the rims guys...Either moto metals or ultra Goliath...I think both these rims look very tuff. I want the offset to stick out a little further than stock to give it a wider stance. i think +30 is what I need right. please verify
The attached files have the stock TRD 18x8 offset highlighted. You can plug in what you are considering and the Excel file will show you where your sample compares to stock. The far right column labeled "Beyond Hub" will show you how far your new wheels will stick out beyond the hub compared to the stock wheels.
For example, if you are considering an 18x9 with 30mm offset, that will stick out about 1.7" more than stock; 35mm offset would be 1.5" more than stock. Play with the numbers to pick what works best for you.
07 DC SR5 TRD 4x4 5.7 TRD exhaust, 46K miles, 17 mpg city after battery disconnect reset. Truxedo Lo-Pro with deck rails. Front Susp: Stock coilovers, 4" lift (http://www.tundrasolutions.com/forum...6-4-inch-lift/), swapped extra spacers for Bilstein 5100s on lowest setting, wheel well height still 41.5." Rear Susp: ProComp ES3000 #326510 (2.25" taller than stock), 1.25" blocks plus PRG mini-pack (http://www.tundrasolutions.com/forum...and-new-truck/) gives 2.25" total lift, parking brake cable bracket spacers, wheel well height 43." Front diff and rear ds drop; trailer hitch electrical harness tucked up above bumper. After 20K miles swapped 305/65/18 BFG AT for 285/75/18 Toyo AT, still on stock 18x8x60 offset TRD wheels, about 1/8" clearance to sway bar. Like the extra height but miss the width. Next time either 305/70/, 295/70, or 35x12.50/18. Added 5th 285/75/18 Toyo AT as spare. Bed Bounce: Stiffer E-tires are worse than stock P-metric; biggest improvement from PRG mini-pack, slight improvement from shocks. Still a stiff ride but tolerable now. Best things about this truck: 5.7 and transmission, interior size and comfort, very quiet at high speed. Worst things about this truck: bed bounce, no VSC in 4wd, mileage sucks above 70.
