02-04-2008, 09:51 PM
Assistant Administrator
DIY (Do-It-Yourself) & User Knowledgebase
This is what makes an owner's forum successful, member feedback and commraderie. Here is a list of Do-It-Yourself projects with instructions from other members.
Enjoy!
General Knowledge, Mods, How-To'sMaintenance Help Topics
Member Install Guides
- Camburg UCA, DIY Install (by: Derek24)
- Recon LED Bed Lights, DIY Install (by: pistolpete)
- Hellwig Rear Sway Bar (7700 series), DIY Install (by: 5 Speed)
- Downey HD Sway Bar End Links, DIY Install (by: Tundradrenalin)
- Superlift TruSpeed Speedo Recalibrator, DIY Install 2005 Tundra AC (by: Tundradrenalin)
- Superlift TruSpeed Speedo Recalibrator, DIY Install 2000 Tundra AC (by: cajuntundra)
- RAAMmatt Sound Deadener, DIY Install (by: dibble9012)
- Brake Caliper, DIY Upgrade (by: MEvang)
- Scangauge II, Install Guide
- 807096 Billet grille instructions.pdf
- OEM Keyless Entry RS3000 Install Tundra00-.pdf
- OEM Keyless RS3200 Programming Guide.pdf
- Window Trim/Exterior Molding Replacement, DIY Install (by: MOREPOWER)
Wheel & TiresOther Useful Knowledge
If you have a DIY thread you would like to add, send a moderator a PM with: - the thread title
- a link to the thread
- the originator of the DIY
And we'll add it to the list. Also, if you stumble on any dead links, report them!
Thank you for your ongoing support!
Reason: Adding more stuff!
