  #24 (permalink)
Old 02-06-2008, 10:17 AM
mustang67408's Avatar
KE7WLF Master of Disaster
mustang67408's Photo Albums
mustang67408 will become famous soon enough.
Default Re: Check Engine Light/VSC Light remain on
Originally Posted by A K View Post
Hi and thanks for replying ! I actually recently replaced the battery to a new one, but this did not solve the problem ! any other ideas ? Thanks for your time !
PS I read that some get rid of the VSC lights problem by replacing the gas cap. Do you think it *may* work in my case as well ? ? ?
There should be a code stored with the VSC light on. What is it?
Nigel tundra: Coincidence
23 yrs with TOYOTA
Official Donahoe Certified Installer & Dealer
K.I.S.S.
