Re: Sad story (need advice)
There is a product called Lanka blob remover, or something along those lines. I've used it many times, I bought it online. Basically you fill the scratch in with touchup paint then you use this stuff like a wax on a rag wrapped aorund a credit card and it removed the high spot on the touch up. It works pretty well.
Also, if you have any guts, fill it in real good with touch up, sand with a Maguires 1500 micro sanding block and then with a piece of 3000 grit. I did this to a bird crap stain on the hood of my BLACK 300ZX. You can't even tell I did it. I also did a spot the size of a dime on my moms burgundy LS430. With that fine of a grit, you wont sand through unless you get stupid.
2005 Tundra Crew Cab 4x4 Limited
Bilstein 5100's set to 2.5"
Spidertrax 1.25" Hub/Wheelcentric Adapters
06 Factory TRD 16" Wheels
ToyTec 1.5" Rear Blocks
ToyTec Diff Drop
BF Goodrich 285/75R16 AT's
