Re: BAD vibration and bed bounce when braking!
It sounds from your description that the rear brakes could be the problem. I would have them checked right away. You could have an axle seal leaking fluid onto the shoes. This is just a hunch from what you have described as "bed bounce" that I take happens while stopping.
Mike
“The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein)
Moderator Brake Forum
