Old 02-12-2008, 06:17 PM
partyman66 partyman66 is offline
partyman66's Photo Albums
Last Online: 11-18-2008 10:47 PM
partyman66 is on a distinguished road.
Default Re: HELP! excessive front end noise and vibrations
Originally Posted by john01374 View Post
As stated above I have the same problem. The noise is much worse when cold and sounds like it's coming from the drivers front. Starting at about 40F I start hearing it and the colder it gets the louder it is and the longer it lasts. It does go away after about 10 mins and i don't notice it over about 35mph. It was really cold last night so I had a chance to try different things to get it to go away. I brought the truck in the garage a rotated the tires again, still there, swapped the fronts left to right, still there. while driving i put it in 4WD and the sound went away instantly. Took it out of 4WD and the sound was back instantly. Does this still sound like bearings? I'm stumped and i don't really wanna throw several hundred dollars at this truck trying to find the problem. BTW I first reported this problem to the dealer around 15K miles and they couldn't find a problem.
Did you have any luck with finding your noise? Mine seems to be getting worse, and I fear that my truck is going to break catastrophically in the next few weeks as a result... but don't know what to do about it. The noise is pretty damn noticeable now when it's cold out. I'm going to try again tonight to see if it definitely only does it in 2WD, but I thought I was fairly conclusive before in my testing that it only did do it in 2WD and not 4WD... we shall see I guess. It sounds like a bad bearing noise, and it is directly related to the vehicles speed, regardless of what gear i'm in.. or if I'm in neutral.. clutch in or clutch out, and even with the engine on and off as I'm coasting from about 45/50 MPH.
-2004 Infiniti G35 Coupe 6MT, Diamond Graphite/Graphite, Navigation, Aero Package, Premium, Brembo Brakes with Project Mu B-Force Pads, Z-Tube and Amsoil EA Air Filter, 3/8" Motordyne Plenum, 18" Wheels w/ Falken Fk-452's 245/40/18 - 255/45/18
-2001 Toyota Tacoma Stepside SR5 5-Speed 4X4 with crappy Nerf Bars, Bedliner and Tonneau Cover, Amsoil EA Nanofiber Air Filter, Bridgestone Dueler AT Revo 275/70/16 Rubber, and a ScanGauge II
