02-14-2008, 10:19 PM
Re: 2008 Transmission Problems Too!
Originally Posted by tacomatrdsport2591
It seems to make sense to me in a way...the transmission is simply trying to get the best fuel economy by having the lowest revolutions per given speed, so it quickly shifts to top gear if it thinks you aren't going to need the speed. But it's just alittle needless, as we've recognized, to pull into fifth at 40. The engine maybe doesn't have enough torque to pull smoothly in top gear at that speed and the computer is getting frusterated, and in the attempt to maintain good fuel economy, if you're not stomping the gas pedal, it'll remain in that gear. Some transmissions from other car makers are just they opposite-downshift-crazy, to create the illusion of speed that comes with the shift-shock.  haha just tryin to put my two cents in...not sure if it brings much to the party, but hey, it's worth a try =]
It just sounds to me like the computer needs alittle reprogramming to move around the shift points alittle and add some logic to its thinking. btw hope I'm not really repeating stuff....I did the lazy thing and didn't read all the posts
Mine doesn't shift into 5th gear until 49-50 mph.
If I slow down to 40, with a little gas it will start to lug.
Just a touch for pedal and the torque converter will unlock or shift into 4th without any problem and accelerate.
Hard to believe they have screwed up the programming in the later builds.
'07 Japanese XLE I4 (Heated Leather, VSC, Mats), Dual Exhaust, K&N Air Filter, Mudguards, Modified Front/Rear Emblems, Lip Spoiler, MTEC 4,350 K High, Low and Fogs, Painted Fogs, Chrome (GS300 Wheels, Pillars, Hybrid Grille, Lower Grille, Trunk Accent, Door Handles), Wood Steering Wheel, LED Tail lights, 19MM Rear Sway Bar, Strut Bar.
