Re: Houston OFF ROAD MEET?!?!?!?
249 and beltway. If you are going east on the beltway you exit right before 249 and its a huge piece of land to the right hand side.
Its a more then a hundred acres or maybe even larger. There are dirt roads all throughout it that will be fairly muddy right now. Anything off the road the general dirt roads and you will need 4wd when its wet for sure. They have also been doing construction on one end of it as well so there are some really muddy areas as well. Theres this one area thats a huge gravel mountain the city uses.
the tundra made it up to about 20ish feet from the peak. I had no traction and at the angle i was i couldnt see the floor.-Ididnt want the loose gravel to tear up my paint so i didnt give it too much gas. id guess the pine is 100ft high.
This place is pretty nice to test out your vehicle and learn what your limits are.
 TUNDRA786
2007 Tundra Crew Max 4.7 TRD 4x4
285/65/18's with BF Goodrich All Terrain KO's
BedRug, Undercover, Bed Extender, Husky Liners
