Re: Heater quit... sort of
Hard to believe you messed things up that bad, double check these things...
- The ribbon cable that can be seen thru the clear window in the back of the control cover. Is it connected properly? Might have come loose from moving the cover around?
- Did you have the other rear connectors plugged in firmly?
- Post a pix of the board you think you damaged.
