Re: Heater quit... sort of
Thanks I will post a pic later.
The connectors are firmly plugged in, yes the ribbon cable is connected as it was, i even tried inverting it, to be sure I had it correct. Then I righted it and reconected everything, so I reconnected all the connectors 3 times and still only the fan works, all other controls/ lights are out.
I soldered the wires on the back side (where the PCB traces are) so that I did not have to take the board out of the front casing, after soldering it looked like the joints were too close so I filed between them, was very tired and I notched fairly deep into the board between the three joints (2 notches). Thanks for your help, perhaps that board can be repaired.
