  #31 (permalink)
Old 02-17-2008, 04:08 PM
Picasso's Avatar
Picasso Picasso is offline
Picasso's Photo Albums
Last Online: 02-23-2008 04:39 PM
Picasso is on a distinguished road.
Default Re: Problems After Dealership Oil Change - Any Ideas?
Originally Posted by cupidstoy View Post
couple of things i didn't see mentioned.
did you check the motor mounts? a loose or cracked motor mount could be a possible source of vibration.
you said your exhaust still sounds louder. any chance the muffler shop ripped you off and put a used or bogus (or non at all) catalyst in your cat location on the side they replaced? that might cause the type of left/right bank imbalance that could introduce vibration and would also account for a different exhaust note and the CEL.
just some thoughts. sorry your having trouble.
cupidstoy
I've checked the motor mounts a couple of times over the past year. They are in good shape.
I purchased the cat myself and have removed it once to check the honeycomb elements. It's all there. I also peeked at the cat element through the y-pipe a few days ago while changing the graphite donut gasket where the y-pipe connects to the muffler.
Appreciate the help.
Paul
Completed Mods:
S&S long tube headers
Brembo rotors
TSB caliper upgrade
Akebono ProAct ceramic pads
Stainless steel braided brake lines
Total Chaos steering rack bushings
Alignment to DJ's specs
Century cap
Line-X
XM Commander satellite radio w/USA Spec dual aux input adapter
Future Mods:
Rearview camera system
Sound deadener
Fusion Drive
Flux Capacitor Control Unit (FCCU)
