Re: Toyota Brake Specifications: Highlander 2001-2006
Highlander: 2001-2006
Front Brakes
Calipers: Single Piston Sliding PIns
Caliper Torque: Caliper Pin Bolts 25 ftlb
Bracket to Upright Bolts 79 lbft
Maximum Parallel
Variation: Not Specified by Manufacture
Runout Limit: .0020"
Normal Thickness: 1.102”
Minimum Machining: Not Specified by Manufacture
Discard at or Under: 1.024”
Finish Microinch: Not Specified by Manufacture
Rear Brakes
Type: Disc
Calipers: Single Piston Sliding Pins
Caliper Torque: Caliper Pin Bolts 25 lbft (32 lbft 05-06)
Bracket to Upright Bolts 44 lbft (58 lbft 05-06)
Maximum Parallel
Runout Limit: .0059"
Normal Thickness: .433”
Discard at or Under: .390”
Park Brake
Type: Drum
Nominal Diameter: 6.690"
Discard At Or Over: 6.730"
Wheel Nut Torque: 76 lbft
Special Bleeding Procedures:
1. Bleed the wheel brakes, no sequence given.
2. After bleeding air from the brakes system, if the height or feel of the brake pedal cannot be obtained, bleed air from actuator assembly using Hand-held tester by following steps below.
A. Depress the brake pedal more then 20 times with engine off.
B. Connect Hand-held tester to the DLC3
C. Turn ignition switch to the ON position
D. Select "Air Bleeding"
E. Bleed the air by following the steps displayed on the Hand- held tester
“The significant problems we have cannot be solved at the same level of thinking with which we created them” (Albert Einstein)
Moderator Brake Forum
