  #41 (permalink)
Old 02-21-2008, 07:33 PM
Picasso's Avatar
Picasso Picasso is offline
Picasso's Photo Albums
Last Online: 02-23-2008 04:39 PM
Picasso is on a distinguished road.
Default Re: Problems After Dealership Oil Change - Any Ideas?
Originally Posted by mustang67408 View Post
We fixed a 07 Tacoma today with a P0451 (Vapor pressure sensor fault).
The customer had installed a NEON license plate frame and had it wired into the trailer wiring. The neon converter box was BACKFEEDING Thru the tailight ground circuit to the ECU and causing ELECTRICAL FEEDBACK NOISE on the Vapor pressure sensor Feed wire.
Have any aftermarket parts installed??????
I know thats probably not your issue, but it can happen.
I'd like to see whatever info you can send, IF I AM ABLE TO VIEW IT.
The aftermarket stuff that I have includes:
- S&S headers
- Cap that's been on since day one
- USA Spec aux input adapter that's plugged into the back of the head unit
- XM satellite radio tuner that draws power from the head unit power leads
I think that you need the Auterra application to replay its data files but I'm not sure of that. At the very least I can take screen shots of the line graphs which would give you a pretty good idea of what's going on, especially if I zoomed in on any part of the graphs. The screen shots are saved as JPEG files that I can then send to you.
Paul
Completed Mods:
S&S long tube headers
Brembo rotors
TSB caliper upgrade
Akebono ProAct ceramic pads
Stainless steel braided brake lines
Total Chaos steering rack bushings
Alignment to DJ's specs
Century cap
Line-X
XM Commander satellite radio w/USA Spec dual aux input adapter
Future Mods:
Rearview camera system
Sound deadener
Fusion Drive
Flux Capacitor Control Unit (FCCU)
