Old 02-22-2008, 06:03 PM
Comattack's Avatar
Comattack Comattack is offline
My eBay Comattack's Photo Albums
Last Online: 10-16-2008 01:45 AM
Comattack is on a distinguished road.
Default Re: Prerunner in sand
There this cool sand wash I like to run my truck in around here and I wheel my 4x4 Taco in the sand using only 2WD probably more then even use 4wd.
It's all a matter of technique..
Wet sand won't be a problem, you should be able to stay on top of that just fine.
Here are a few pointers for hitting the sand in 2WD.
-TIRES! Street tires ain't gonna cut it no matter what you do. Get some good offroad tires, preferably some M&S rated tires that are wide with some good sidewall bite. You need all the traction you can get.
-If you only have 2WD, might as well be locked.... 'nough said!
-Air down... larger footprint = better floatation. You want to stay on top of it!
- Keep moving! The deeper the sand is, the more critical it is to stay on top of it. Slow down and you will begin sinking which causes more friction, which in turn slows you down, more friction, spin tires..... you get stuck...
- As much as is possible ROLL to a stop. Don't slam the brakes. Getting on the brakes causes the front wheels to dig in, which makes it harder to get started going again.
-Keep your truck as light as possible! Don't carry extra weight. It'll just contribute to your sinking!
-Make large sweeping turns. Don't crank the steering wheel. Cranking the wheel causes too much resistance, and your front tires will begin to plow more than they will actually turn. This is more forgiving at higher speeds. Low speeds, "forget about it!" Also in the sand, at higher speeds it requires much less effort to whip the rear end around. However, don't drive beyond your ability. Wouldn't want ya to roll dat purdy truck or yours (whatever you get)!
-When accelerating from a stop try to avoid spinning the tires. You'll just dig in before you get moving and you'll get stuck. Accelerate slow and you can roll through the sand without digging in.
-ALWAYS HAVE A BACK-UP PLAN! You are way more likely to get stuck in 2wd than 4wd. Like I said, I like wheeling in the sand in 2wd, but if you don't have 4wd as a back up, make sure you have a buddy that can pull you out, or have a shovel and some boards to help get yourself out.
I can't emphasize knowing your limits and/or having a back-up enough.
If the sand is super soft (the kind you sink in when wet), 2wd is never gonna cut it unless you have some some crazy wide tires. Very grainy sand (like beach sand) is much easier to maintan floatation on. If you still have a choice, I'd say get a 4WD.
With some experience & skills you can get around in the sand with 2WD pretty well, but at some point, you WILL get stuck. Count on it! Just be prepared to get youself out, and don't get stuck where you can't get any help (either because of communicationn issues or accessability issues).
Have fun!
MUD IT!!
