  #39 (permalink)
Old 02-23-2008, 02:35 AM
re.ac.tor's Avatar
re.ac.tor re.ac.tor is offline
Last Online: 11-20-2009 04:23 AM
re.ac.tor is on a distinguished road.
re.ac.tor's Photo Albums
Default Re: DIY: How-To-Enable DRL – 2007 Tundra
Originally Posted by abutterworth View Post
Also, when using a SPDT rocker switch on wire Relay A wire 86 I think I go into the center post on the switch and out one of the others. Do I leave the remaining post empty?
Thanks.
abutterworth,
I do not know the answer to your first question but can help with the second:
The posts on your switch should be labelled (or the packaging should indicate) that one post is power (positive), earth/ground (negative) and load. The wire in question should connect at the power and load posts and the earth/ground post should be connected to a grounding point on the truck.
Hope this helps, re.ac.tor
CURRENT Tundra:'10 CM SR5 4x2 Constructed & Purchased in September 2009, 5.7L, Sandy Beach Metallic
OLD Tundra:
'07 DC SR5 4x4 Constructed & Purchased in May 2007, 4.7L, Texas Edition,
Enkei Wheels, Nautical Blue Metallic, Sirius InV, Line-X, Recon CCLs.
Drug Information in Lay Language
