Re: Disable the ABS on a 2003 Tacoma
The only way to disable your ABS is to pull out the ABS fuses in the fuse box under the hood. I'm not sure about runnng a switch to the fuse but simply pulling the fuses is easier.
Yours might have one or two ABS fuses if it's two or four wheel ABS.
