Re: Can I put an ATV in a crewmax?
Originally Posted by Toxarch
Wow, you went all fancy with the metal edge on the plywood. So did you use a treated plywood? Guess it won't matter that much in Tucson.
I see you put a piece of plywood at the bulkhead. Not a bad idea. I use two tie downs from the front of the 4 wheeler to the back corners of the bed to hold the 4 wheeler a few inches away from the bulk head. I guess either way works.
It actually works to. I've popped the bulkhead a couple of times good and have not bent it yet with the plywood. That's saying a lot when your talking about close to a 1000 pounds.
2007 Tundra SR5 5.7,2WD White Crewmax
Toytec 3 Inch lift,Procomp 6066 wheels
Firestone airbags with compressor
305/55/20 Tires,Step Rails,Dash Mat
Xm Radio,Magellan roadmate 2000 Nav
Bed Extender,Carbon Fiber Dash Kit
