Re: My Runner turns off
Originally Posted by TheUser
Yesterday it happened about 3 times, that I accelerate my runner (3.4V6) harder than normally, and when i took my foot out of the gas it turned off...
Does anyone knows why did that happen? Maybe there is a problem with the fuel pump, or something...
Thanks
Sergio
Sergio,
I had the same thing happened to my 2000 LTD 3.4 a few years back only when I start it would happen; no CEL would come on but when I took it in to the dealer, they diagnosed it as the Idler Speed Control Valve (ISC) going bad. Once they replaced it, no problems ever since. Costed about $250+. Hope this helps.
2007 Tundra CrewMax LTD 8272 Black/Sand Biege - Navigation, Rear Seat Entertainment, 20" Alloys, Sunroof, Mudguards, Sonar, DTR, V2 Alarm w/GBS.
MODS: Line-X, RETRAX, Tech Formula Paint Sealant, Debadged, Clear DRL's, AMP Powerstep Running Boards, 2.4" ReadyLift, Nitto Terra Grapplers 305/55/20's on OEM LTD 20" Alloys, Ravelco Anti-Theft Device, aFe CAI Stage 2 ProDry S. NEXT MODS: Corsa Performance Touring Exhaust, Black Headlight Mod.
2000 4Runner LTD Millenium Silver 2WD - TRD Intake Air Filter, Clear-Corner Parking lenses, partial Debadge. Removed: Poweraid Throttle Body Spacer
1965 Ford Mustang 289 cid Laser Red - 5 spd, McLeod Clutch, Hydraulic Slave Clutch Cylinder, 3:89 Trac-Loc, 9" Lincoln Versialles Differential, 4 Wheel Disc Brakes, SVO Aluminum Master Cylinder, Simmons F90 custom wheels with Front/Rear width off-set, TFS Twisted Wedge heads, Holley 650 Double Pumper, Crower Custom CAM, Hooker Headers, Flowmaster w/H-pipe 2.5", SPAL fan, Weiand Stealth Intake - Mid 13's at 104 MPH street tires!
SOLD: 1993 Toyota Truck Xtra Cab SR5 2WD - E&C Spring UCA 3" lift, ProComp 3" Body lift, ProComp ES3000 Shocks, Rear Add-A-Leafs, 14mm Sway-Away Torsion Bars, Custom Skidplate and Driving light bar w/PIAA 40 Driving lights, Hella H4 Headlights, Optima Battery, Jacobs Omni-Pak w/8.5mm wires, K&N FIPK, FlowMaster 2 Chamber 2.5" CAT-Back Exhaust, 10 deg. Advanced Timing, Western 15x8 wheels, BFG TA KO's 31x10.5x15, 4.11:1 Gears w/Tru-Trac TracLok.
IYAOYAS!
