  #28 (permalink)
Old 02-29-2008, 09:02 AM
Gunner Tundra's Avatar
Gunner Tundra Gunner Tundra is offline
Last Online: 11-21-2009 12:08 AM
Gunner Tundra is on a distinguished road.
Gunner Tundra's Photo Albums
Default Re: AMP Research Powerstep running boards
Got mine in this week and completed the install myself. Fairly simple; took about 3.5 hours from start to finish. The only real problem that came up during the install was the wire colors for both rear door trigger wires.
The driver side rear door wire is dark grey from the AMP harness, but in the wiring loom of the truck, there are (2) dark grey wires. You have to open the rear door switch to see the true color that is connected to it, then locate it in the loom, then to determine which one is the correct one, use a multi-meter and look for the 11.84 ~ 12 VDC read out when the rear door is open and check it when closed at 0.0 VDC and that'll be your wire. Same with the passenger side rear door. There are (2) green wires as well. Not sure if it's only like this for the 07's though.
Don't forget to relocate the E-brake bracket located in front of the rear wheel well as per the instructions (which isn't clear on the location). You'll have to bend the lock tab flat to the frame. Hope this helps.
Linkage uses factory running board holes.
Installation of Controller module
Trigger wire connections passenger side
Power Steps fully retracted
Power Steps fully extended
E-Brake bracket shown with tab flattened and reinstalled with cable above thread hole
These things are awesome! They hide very well and are light wieght yet durable. $1200~ was my cost.
2007 Tundra CrewMax LTD 8272 Black/Sand Biege - Navigation, Rear Seat Entertainment, 20" Alloys, Sunroof, Mudguards, Sonar, DTR, V2 Alarm w/GBS.
MODS: Line-X, RETRAX, Tech Formula Paint Sealant, Debadged, Clear DRL's, AMP Powerstep Running Boards, 2.4" ReadyLift, Nitto Terra Grapplers 305/55/20's on OEM LTD 20" Alloys, Ravelco Anti-Theft Device, aFe CAI Stage 2 ProDry S, Corsa Performance Touring Exhaust. NEXT MODS: TRD Sway Bar, Auto Tailgate.
2000 4Runner LTD Millenium Silver 2WD - TRD Intake Air Filter, Clear-Corner Parking lenses, partial Debadge. Removed: Poweraid Throttle Body Spacer
1965 Ford Mustang 289 cid Laser Red - 5 spd, McLeod Clutch, Hydraulic Slave Clutch Cylinder, 3:89 Trac-Loc, 9" Lincoln Versialles Differential, 4 Wheel Disc Brakes, SVO Aluminum Master Cylinder, Simmons F90 custom wheels with Front/Rear width off-set, TFS Twisted Wedge heads, Holley 650 Double Pumper, Crower Custom CAM, Hooker Headers, Flowmaster w/H-pipe 2.5", SPAL fan, Weiand Stealth Intake - Mid 13's at 104 MPH street tires!
SOLD: 1993 Toyota Truck Xtra Cab SR5 2WD - E&C Spring UCA 3" lift, ProComp 3" Body lift, ProComp ES3000 Shocks, Rear Add-A-Leafs, 14mm Sway-Away Torsion Bars, Custom Skidplate and Driving light bar w/PIAA 40 Driving lights, Hella H4 Headlights, Optima Battery, Jacobs Omni-Pak w/8.5mm wires, K&N FIPK, FlowMaster 2 Chamber 2.5" CAT-Back Exhaust, 10 deg. Advanced Timing, Western 15x8 wheels, BFG TA KO's 31x10.5x15, 4.11:1 Gears w/Tru-Trac TracLok.
IYAOYAS!
