Old 03-03-2008, 01:45 PM
zpaul's Avatar
zpaul zpaul is online now
Last Online: Today 09:15 PM
zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor. zpaul is a superior contributor.
zpaul's Photo Albums
Default Re: Getting the stock NAV to accept DVD output
Originally Posted by StatCoder View Post
One setup seems to be to tap into the feed from the backup camera. I guess that would mean also doing whatever is necessary to turn the camera video feed on while driving. I supposed I need the speed pulse generator. I'm not sure, though, how to get the backup camera video feed to turn on, though. Then, I'm hoping to wipe out the backup video "check surrounding" red letters by replacing the letters in the code with spaces and reburning the nav DVD.
What are your thoughts? Your advice is appreciated.
You do not need pulse generator for DVDs on NAV. You just need to tap into back up camera. Although some relays will be needed and a switch, that will fool the NAV that you are in reverse mode, but relays provide the feed from DVD player, whatever you decide to use, even iPod can work, as long as those RCAs are accessible.
WileETundra did it with his NAV. I did it as well, but with pro help. WileETundra had a description how to on his site. Under NAV DVD player hack.2007 Toyota Tundra Mods by WileETundra
Pulse generator is tapping into a speed sensor wire. So I have 2 switches (Chiplee thanks those are looking good). One to play DVDs in my case it is from overhead. Second to access the NAV functions. Here you go.
2007 Toyota Tundra CrewMax Limited 5.7L 2WD, Timberland
