Thread: 295/70/17
Old 03-05-2008, 09:30 AM
jamesjr4750's Avatar
jamesjr4750 jamesjr4750 is online now
Last Online: Today 02:31 AM
jamesjr4750 is on a distinguished road.
jamesjr4750's Photo Albums
Default Re: 295/70/17
Originally Posted by Empire12 View Post
I am going to buy new wheels & tires for my 2000 tundra 4x4 with bilsteins on highest setting. I was wondering if 295/70/17 would fit with american racing crater wheels, the backspacing= 4.5 & offset=-12mm. I also have 1.5in wheel adapters if I need to use them
I have a winter set of tires in a 275/70/17 that are 32.2" tall x 11.2" wide and those don't rub mounted on 17x9 Centerlines with the 4.5" backspacing and -12mm offset ( clears caliper with those wheel specs) There is alittle room of about 3/4" or more at full lock. Who knows they may work with those 295's, order up a 1/4" wheel adapter/spacer from Wheelers Offroad, but then you aren't going to have many threads left for the lugs. It would then probably be necessary to get longer ARP studs so you dont end up snapping the stock ones off. If it ends up not clearing like you said, you've got those wheel spacers
I say just get the 295s with the 17x9 with the given wheel specs and go for it. Then tell us if it works or not. Most people aren't clear enough on "Aftermarket wheels" and their specs to help on issues and where it rubs like mad. What kind of tire and especially what brand has a lot to do with if it rubs or not. Mud Terrains for instance have outer lugs on the sidewalls and usually rubs the inner frame as what I experience on my 305/70/16's (33.1x12.3) using 16x8 Wheelers Offroad steelies with the 4" backspacing wheels. And even with my coilovers set at 2.5" of Lift it still rubbed the pinchweld before trimming as well as the plastic inner fender, mud flaps. Have fun fitting those 295's. Its going to take some work
03' Access Cab Toyota Tundra V-8 4.7L, 4x4
305/70/16 BFG Muds on 4" B/S Wheelers' Offroad Steel Rims
Donahoe Racing Coilovers (cranked 2.5")
Total Chaos Upper Control Arms and Rack Bushings.
ORS upper mount shock hoop kit / FOX Racing 2.0" Reservoir 11" travel shocks w/ Deaver G57 10 pack rear springs
ARB Sahara Bumper with Fog Light Kit and KC SlimLites in Front
