  #124 (permalink)
Old 03-10-2008, 11:13 PM
StatCoder's Avatar
StatCoder StatCoder is offline
Last Online: 10-15-2009 12:16 AM
StatCoder will become famous soon enough.
StatCoder's Photo Albums
Default Re: DIY: All NAV Functions All The Time without Firmware Downgrade!
I used the cigarette lighter because I think it's only on when the ignition is on while the accessory plug is on for ten minutes or something after the ignition is turned off. I believe the gray wire is the hot lead. When I looked at the accessory plug, it looked like the white/black stripe was hooked up to the outside part of he receptacle (ground) and the colored one (can't remember the color) was hooked to the tip (hot). So, I figured the cigarette lighter must be the same way. I lost the leads to my multimeter so I had to go with that and it worked. I'll be taking a look at again, tonight, and will correct this message if I'm wrong. [this is confirmed]
2007 5.7 CrewMax Limited 2WD; Pyrite Mica/ Red Rock Leather
20" Alloy | Nav-JBL | Moonroof | Sonar | Cold Kit | Daytime Running Lights | BedRug | ConsoleVault | SoftTopper | TRD sway bar | Weatherguard Tool Box
NAV Mods: Speed Pulse Generator | AUX video input
Buy your truck outside of the Gulf States Toyota monopoly if you don't want to compromise.
