  #29 (permalink)
Old 03-11-2008, 08:30 AM
WT's Avatar
WT WT is offline
Last Online: Today 01:25 PM
WT is a splendid one to behold. WT is a splendid one to behold. WT is a splendid one to behold.
WT's Photo Albums
Default Re: Getting the stock NAV to accept DVD output
Originally Posted by wileetundra View Post
Gang:
I posted a thread many months ago about how to enable the video via the rear camera input. It included pics and links to wiring diagrams. It is pretty easy, a simple toggle switch on the REV line into the NAV. Only issue is the disclaimer text which appears, and I am working on the next mod to enable the rear DVD input while in motion to get around this, but honestly I have been using the rear camera method for months and I don't even notice the disclaimer now. It is also nice to watch the rear camera on demand. So I suggest that you checkout my old thread for a cheap and quick solution in the interim, unless you have $450 to spend and want to try the device posted above. Those over-priced solutions are the reason I keep inventing - just isn't fair for them to gouge people like that.
WileE
Yeah guys its rather simple a matter of adding a switch (SPDT used same switch as I did for SPG) to the Rev wire to the NAV head unit. I found all the information I needed from WileE posts lots of good information hes got about different things and what wire does what. If your to lazy to search for WilieE post which I found to be alot of great information in general.
All I did was wire a +12V source to the switch and intercepted the green wire next to the speed wire you tapped your SPG (K6 I think it was) to which made it easy since I was back there already and thats all there was to it. So when the switch is in normal state the rear camera only comes on when you go into reverse and when the switch is on it toggles the +12v to the NAV unit to fool it into thinking the trucks in reverse. So to add video its a matter of intercepting the rear camera input to the NAV and injecting your own source, a simple relay make it simple. I am thinking it be a easy build to make a simple relay box to do this or as WileE did in his post he added a video switcher which is a great idea then you can have a few different inputs, which was a awsome idea.
2007 CM Limited Blue Streak
Click below for Auto Tailgate Project:
http://www.tundrasolutions.com/forums/tundra/116550-automatic-tailgate-unlock-lock-projects-pics/
DVD Headrest:
http://www.tundrasolutions.com/forums/tundra/120927-dvd-headrest-installed-about-350-00-a/
DIY Painting door handles (color match):
http://www.tundrasolutions.com/forums/tundra/121391-diy-paint-your-door-handles-match/
Bakflip and Bedrug:
http://www.tundrasolutions.com/forums/truck-bed-tonneau-covers/113644-g2-bakflip-installed-crewmax-w-pics/
Color match grill/Clear Bra/Other Stuff:
http://www.tundrasolutions.com/forums/tundra/112118-mod-weekend-with-pics/
Billet grill installed:
http://www.tundrasolutions.com/forums/tundra/124082-billet-grill-arrived-and-installed-pics/
Black Headlight Mod:
http://www.tundrasolutions.com/forums/tundra/126864-completed-my-diy-black-headlight-mod/
TPMS Bypass:
http://www.tundrasolutions.com/forums/tundra/142895-tpms-diy-bypass-completed-tested-pics/
Truxxx Lift:
http://www.tundrasolutions.com/forums/tundra/136860-truxxx-lift-install-w-pics-thoughts/
How to fit 35" Tires with body mount mod:
http://www.tundrasolutions.com/forums/tundra/138052-lifted-with-35-and-pictures-share/
