  #130 (permalink)
Old 03-12-2008, 12:08 PM
wileetundra's Avatar
wileetundra wileetundra is offline
Super Genius
Last Online: 11-03-2009 11:15 AM
wileetundra is on a distinguished road.
wileetundra's Photo Albums
Default Re: DIY: All NAV Functions All The Time without Firmware Downgrade!
Originally Posted by kt8509 View Post
Will this work with a non-nav unit? I have a CM Ltd with the JBL / Bluetooth system and while in motion when the phone rings, the display shows "No Name" vs. the Caller ID (it shows the Caller ID when the truck is stopped).
Are you sure it is the motion which is changing the Caller ID function? If so then I think the SPG should work. The factory wiring harnesses are usually the same so you should be able to check the plugs behind your radio to make sure. Look for the 5-pin white flat connector with a white and green wire in it, and maybe a red wire as well. If you have that then it should work.
WileETundra
view all of my 2007 Tundra mods and photos
