  #131 (permalink)
Old 03-12-2008, 05:46 PM
kt8509 kt8509 is offline
Last Online: 12-07-2008 11:35 PM
kt8509 is on a distinguished road.
kt8509's Photo Albums
Default Re: DIY: All NAV Functions All The Time without Firmware Downgrade!
Originally Posted by wileetundra View Post
Are you sure it is the motion which is changing the Caller ID function? If so then I think the SPG should work. The factory wiring harnesses are usually the same so you should be able to check the plugs behind your radio to make sure. Look for the 5-pin white flat connector with a white and green wire in it, and maybe a red wire as well. If you have that then it should work.
Yeah, pretty sure. From the owners manual, page 380:
"When receiving a phone call, the display is as follows. The display differs depending on whether or not the vehicle is in motion.
When the vehicle is stopped: Number, name, or “Incoming” is displayed.
When the vehicle is in motion: “Incoming“ is displayed."
I haven't ripped out the dash to get to the back of the radio yet... maybe this weekend. Do you happen to have any SPG's left?
Thanks.
