Old 03-13-2008, 10:39 PM
Imdone's Avatar
Imdone Imdone is offline
Last Online: 10-31-2009 02:18 PM
Imdone is a splendid one to behold. Imdone is a splendid one to behold.
Imdone's Photo Albums My eBay
Default Re: Long Tube header interest
The gains are guessed to be 40 - 50hp. This is based on a 10 - 15% increase in horsepower. This is what they have seen in the passed with long tubes on toyota v8 engines.
This company does not do dyno testing like most companies. Real world environment isn't in a dyno test booth, it's out on the road.
What I have done in the passed is used a G-Tech Pro which is an in vehicle dynamometer which results with real world dynos. I will also be going to the track with another T/S member and can test there with some before and after time slips as well.
I however will not be able to provide this until after they are made and they won't make them until there are enough people that want them.
The cats may be bolt on, this has not been decided. They will supply them and if you want to fab your self then it's all you. They won't be supplying everything to eliminate the cats all together though.
RBP, ICON, CAMBURG, ALCAN, AMP RESEARCH, TOYO, ECLIPSE, SAVV, FOSGATE, KICKER, JL AUDIO, V-LEDS, PIAA, HELLA, MBRP, UNICHIP, TIMBREN, HYPERTECH
