Re: High flow cats?
Usually the O2 sensors go into the pipe before or after the cats, not actually into the cats so changing them is a non-issue.
I have a pair of new un-installed 3" high flow cats that I would be more than happy to get out of my garage. I believe they are magnaflow cats and were $100 each to me.
I gladly let them go for $100 for the pair with gaskets. They have a 3 bolt flange on both ends but can be cut off or you could put a 3 bolt flange on them and run them and still be able to swap out for others.
Work in progress...
