Re: Excessive BODY Roll - 2007 DC 4x2
It is a tall and heavy vehicle, with even the lightest variants sneaking over the 5000 lb mark. Simple physics dictates it will not handle with abandon. That being said, things can be done to give substantial improvements. A factory rear sway bar is available which should keep things a little tighter. Have a look at the associated threads and observe the comments of those who have purchased the bar. Also depending on your current tire/rim configuration, you may be able to substitute a lower profile sidewall arrangement which will reduce sidewall flex when cornering, again with positive handling benefits.
