Old 03-21-2008, 08:14 PM
yspert's Avatar
yspert yspert is offline
yspert's Photo Albums
Last Online: 05-30-2008 03:43 PM
yspert is on a distinguished road.
Exclamation Re: Drive Shift Indicator Bulb is OUT
very simple to do....for most people.
take the trim piece off from around the "glass". typically, it will have
a couple or four screws holding it on. then a socket to remove the cluster.
disconnect the plug(s) and move the "L" bulb to the "D" slot.
reverse procedure and test drive. the bulb may have a green cover
that you have to transfer to the new bulb. lowering the steering wheel
to the lowest position normally helps and don't turn on the key. yspert
Graduated from Y to Z status.
