03-23-2008, 11:26 PM
Re: Rides Like a BRAND NEW Truck!
Originally Posted by ThirdHorseman
Yes, they came with bolts and that is the reason the holes are drilled. However, I've learned through experience with these springpacks that after extended usage, the bolts just tend to squeak and sound irritating. This was the case with the Titans we ran the springpack on as well. So...I don't use them.
This choice is up to the user, but I've discussed this issue with Greg at PRG and he has assured me that the truck will not suffer as a result.
Don't know on the second part - I've never put 1,000 lbs in the bed. Probably 500 at most.
The holes look like they are pretty close to the top of the OE springs. I could see how after you get offroad you will be a little squeeky.
You have 1k lbs of junk you can throw back there to see how it holds up? I would be interested to see the sag with this kind of weight compared to the OE 3/4" lift block/blade.
RBP, ICON, CAMBURG, ALCAN, AMP RESEARCH, TOYO, ECLIPSE, SAVV, FOSGATE, KICKER, JL AUDIO, V-LEDS, PIAA, HELLA, MBRP, UNICHIP, TIMBREN, HYPERTECH
