Re: Write up on O2 sensor replacement?
its the sensor on the driver side exhaust manifold it should be in plain site. (a lift would be very useful if available) I work at an autozone and we loan out the socket to take them out. It will have a wire coming out of the top connected with a clip which can be a pain to get your hand on. One other hazard is the threads being basically welded to the manifold and you will end up stripping it out. If that occurs i'd try some liquid wrench if not, then a trip to the ole mechanic.
